Showing results for tags 'failed relay'.
Found 1 result
  1. Long-time lurker here; I've found many posts here pretty helpful in diagnosing/repairing previous issues. Current issue is a 2003 Tiger River Bengal M that has a non-op jetpump. I get a "jets icon" whenever I turn on the jets or run a clean cycle as well as a red light on D17 on the board. Unfortunately, jet pump (WaveMaster 7000) doesn't respond... not even a hum, so I'm ruling out a bad cap. Motor spins freely too when turned with a wrench. All other items connected to the board work just fine and have 120V across the terminals. I checked voltage across the flag terminals on the jet pump with it turned on and I get between 4.2-5.1V. Is it possible that a relay has gone out? I looked around the board for burn marks or other charred remnants and everything looks clean. The board is from 2003, so I'm certain it's getting ready to retire. I just replaced the heater control board last year after one of the relays burned a huge hole in the board. Any ideas on what resistance I should be seeing on the relays? I'm getting ready to run out and get some alligator clips to test them. Thanks in advance for any advice you have!
