Showing results for tags 'cooling'.
Hi all, I hate to have this be my first post, but I wanted to throw this out there before I end up "throwing my tub out there." We purchased our first tub (Emerald Spas E550) in September of this year and tried to do as much research as possible to ensure our maintenance costs would be reasonable. We're in the NYC area so we can have falls and winters with varying temperatures. We typically use the tub on the weekends and heat it to 102F. We use it for a half hour and lower the temperature to ~90 when we're done, covering it with the supplied 4"x2" cover from the shop. When we come out in the morning (about 8 hours later), we find that the temperature has dropped to 90 degrees and the tub is in heat mode. From what we've been told by a few shops, manufacturers and other tub users, we should not see that sort of heat loss overnight. Typically - we're told - is that 2-3 degrees is the norm when using a good cover and the tub is insulated properly. We've had a few folks tell us 12 degree drops are definitely not normal. About the tub: It's on a 240 line in a concrete yard. It has a 4"x2" cover and has the spray foam insulation. It does not have reflective insulation on the panels. We are not running it in economy mode. We've called Emerald and they said it's not normal; call the shop. Called the shop and they say "it might be normal". They've sent a tech to look at the electrical setup and he said it's fine; the spa is working as expected and there's no anomalies in the setup. They're saying a 10-12 degree drop is normal and it's "the cost of doing business" when it comes to a tub - but I can't justify $200 in increased cost monthly to use a hot tub 8 days a month in the winter. We can't leave the tub at 102 all the time because it would essentially be heating all the time. My question is - is a 10-12 degree drop normal? Should I try to add insulation myself to the inside of the cabinet? Should I continue to badger the shop or manufacturer? Am I doing something that hot tub newbies shouldn't be doing? Any help is appreciated and of course, let me know if you need more info.
