Showing results for tags 'control system'.
We have a high pH level and have attempted to adjust the sanitizer output. The output level is stuck at 60% I have attempted to adjust the output by pushing the less button. It will go to 40% but will not go any lower. And then it returns to 60%I have also attempted to make adjustments to the Easytouch control system panel. I followed the instruction booklet and disabled the Intellichlor unit on the panel. However, no change was made, on the slide panel. If I turn off power to the Intellichlor unit at the pentair power box it will also shut off the pool pump. What is your advice?
- 2 replies
- intellichlor
- pentair
- (and 5 more)
New to this forum and getting ready to build a 20x40 igp. I would like to know which chlorine generator, heat pump, pool pump, control system, and light system they prefer. Here is what I am considering. A 30" hayward 2 inch pipe 1.5 hp 2 speed pump, a aqua pro 1300 heat pump (125 btu) , color logic led light, aqua-rite & 40k salt cell. I found this kit at Royalswimmingpools.com. I am also looking into a robotic cleaner. I live in southern Missouri and it will have unobstructed sunshine most of the day. Any input is appreciated. I plan to hire a contractor to do the install, as I do not have the time, talent, or tools for the job. Thanks again. I will keep everyone posted with pictures and progress.
