Showing results for tags 'circuit'.
Found 4 results
  1. Kids pushed Jet switch on and off multiple times. No longer works. Pushing switch does illuminate the switch panel and display the jets graphic on and off. The rest of the buttons work as well (temp up/down). No signs of burnt wires or areas on the circuit board. The Jet Pump does work...ran power directly to test. Appears as though the both the switch and the pump are working as they should. Assuming something with the circuit board. 1999 Tiger River Bengal M. Any help would be GREATLY appreciated.
  2. Well, as the title of the topic states, the circuit board in my Sundance Spa Sentry 800 burst into flames and is beyond repair. The hot tub had been turned off for around two years or so when it had stopped working for no reason. I had winterized it well and thought id try to fix the problem myself this year. i had a feeling it was a fuse problem so I went to radioshack and purchased replacement fuses for the circuit board making sure that they were lower amp so that the equipment would not be damaged and were ceramic as they had been before. i popped in the new fuses and hit the breaker. Mira
  3. Hello - We have a Sundance 850 series 'Marin' hot tub that had a few issues in the past (see post: http://www.poolspaforum.com/forum/index.php?showtopic=26961&st=0) We resolved our previous problem by replacing the circuit board and all of the filters. After we did this in the spring last year, the hot tub worked for about 4-5 months but then just quit working. It gives us the awful "Watchdog" (----) error again. We did some tests and think the circuit board is bad again. So, recently we actually paid a Sundance hot tub tech to come out to diagnose the problem, as we did not want to kee
  4. Hello, i was trying to get my Balboa VS501Z hot tub running, but i wanted to make sure that i have the correct Amps. The back says 16A/32A, So would i set the circuit breaker to 40 to cover both 16 and 32? Thanks in advance for any and all help
