Showing results for tags 'air fitting'.
Found 1 result
  1. If this does not beong here please delete it. I know it's not a "hot tub" but there are really no big communities for whirlpool tubs. I bought (what I believe to be) a Neptune whirlpool tub used but I can not find a model number anywhere on the tub only some type of sticker. It came with some damage to what I believe is an air line fitting at the bottom on the tub and I wanted to know if someone could ID this part for me. Also would this be an easy fix? Also could someone tell me if this tub uses a modern pipe design where the pvc is bent to allow water to drain completely after the tub is drained?
