Showing results for tags 'High speed '.
My hot tub pump works on low speed, maybe not as powerful as it used to be, but when I switch over to high speed it sounds like it tries to start for a second, and makes a click or a thunk sound before cutting out. I can also only get the heat to go to about 60 degrees too. I'm guessing this is related to the high speed pump not working. I have checked all the wiring with a voltmeter, and everything is reading ok. The tub has been filled for a few months, and I ran the cycles to clear any trapped air so I don't think that should be it. Nothing looks to be blocking the flow of the filter either. The breaker never trips, and one thread I found sounded like it could be the capacitor, but that sounds like the low speed wouldn't work, but the high would, which is opposite of my case. I'm thinking I might need to replace the pump, but was hoping someone could confirm that might be the case before I paid the money for a new pump. Thanks for any help in advance. 1619790068_IMG_1401-Trim.MOV
I just purchased a used RLX ZQ 381166. The problem I have is that it runs fine on low speed and heats the water but when I push the Jets button for high speed it trips the "mini-breaker" almost instantly. I can wait 30 seconds or so and reset it and run it on low speed and everything is just fine. What is most likely the cause of this?
