Showing results for tags 'Heater problem'.
Found 2 results
  1. I have a 2005 Hot Springs Grandee Spa model 36675. A new Watkins no fault heater 4kw 240v was installed about 4years ago. The heater just stopped working. I checked the breaker and tried resetting it but it tripped immediately . The heater is on the 30 amp gfi breaker by GE. I tried resetting it after waiting a few minutes and it still tripped immediately. I put a tester on the circuit and that would light for an instant as soon as I tried to reset the breaker, but then the breaker would trip. I then disconnected all 3 heater wires from the control panel and the breaker still trip
  2. I have an older hotspot model z round tub, everything is working except it won't heat up. The seal on the filter is leaking. I replaced the heater, still no heat. Please help.
