Showing results for tags 'Fix leak'.
in my experience the patches and any type of puncture repair kit don't work, too much pressure. best thing to do is locate the hole, deflate slightly. big blob of silicon sealant on your finger and push into the hole (actually push it through the hole) another blob on the outside and leave for 4 hour's, or longer ideally. granted its not the best looking repair, but work's
I noticed I was losing water. I pulled cover panel off and noticed that the drain tube was leaking at the valve. I tried opening and closing the valve, but it's still leaking. Probably just old valve and needs replaced. Can this be easily done? Do I have to drain entire tub to replace the valve? The valve is at the end of the hose/tub that comes from bottom of tub and is used to drain tub. I would assume a trip to spa store to buy the shut off valve and an easy unscrew old and screw in new would fix? I'm new at this so any help is greatly appreciated!
