Showing results for tags 'Control'.
My american whirlpool hot tub was hooked up yesterday and properly installed. The control panel turned on and worked. This is am i fill it up and try to turn on control panel and won’t turn on. Had my electrician come back out and checked GHI and fuses and panels and nothing everything is fine. Blinking red light on american whirlpool tag but control panel will not turn on. Called my company who i got it from to come out and can’t get them out here for 2 weeks!!! any suggestions please!
Hi All, One of the buttons on this topside control (for a wave-lounge) has stopped responding. How do you remove this? I can't see any screws or other fasteners from underneath. Is it just sealed on with an adhesive sealant? Do I pry it off? Use heat? I don't want to break anything if there is a trick. Also, once I get it off are there any serviceable components that I might be able to fix, or is this a replacement job? Thanks, Rob
We had a new pool installed last summer. All Jandy equipment - heater, aqua pure, pump, filter. We went a little overboard on the size and blew our pool budget for the automation features. I'm getting tried of turning the pump on/off. Trying to educate myself on Jandy remote control components however with so many options - I'm very confused. Can anybody recommend an inexpensive setup for the following: Pump Control Heater Control 1 value (deck jets) with Remote Control or iPhone Your advice is greatly appreciated.
I have a 2001 hotsprings GRANDEE I noticed the spa was not hot enough for the girls, tried to up the temp but the display had some weird on it and wouldn't opperate, so i kicked the breaker off to reset( left off for 10 min) when system came back on there was no display @ all and the main pumps would not work the circ pump came on but thats all. i tried to test voltage on stuff all seamed ok, talked to another person who said that there was a problem with the topside ribbon cable on these spas, i unplugged all the connection to make sure there was no corrosion in the way, but again all seams good. ANY ONE HAVE THIS PROBLEM
Newbie here needs help, or advice. I have a down east spa with gfi problems. It was all working fine untill I drained and cleaned/refilled. When I powered it up @ the gfi panel, it started, got to the prime and then triped the gfi. I tried it again and it imeadiatly triped. I then replaced the gfi. To be sure that was good, it triped imeadiatly. All fuses are good, and I tried with all pumps and the ozone, light Ect. Unplugged, and the gfi still triped. I then tried the whole system with a non gfi breaker, then everything powers up normal. Any ideas? WHAT GIVES!! Is the board bad, how do I check and find a power leak to ground? Al
