I Have a vita L700C whenever I try to use the topside panel it always blinks no matter what setting I am in and it wont heat up. The clock will blink, when I change the setting to see the water temperature it continues to blink, when I change it to the set temp of 102 degrees it continues to blink. I have replaced the recirculator pump and the heater element. I am going to put in a new topside panel due to it being hard to read due to the condensation that has built up over the years. All 3 pumps work as they should. I tested the new heater element and the Ohms were within spec. When i turn the breaker on and test the heater for voltage it only reads at 0.023V. The heater element is a 4kW @ 240v system. Any ideas or help to guide me in the right direction would be greatly appreciated.
