IMG_4093.MOV
I have a Solana RX The pump stop running on low pressure mode. Low pressure switch has been replaced. And I know it works.
So I was gone for a week and spa stop running on low pressure and stopped heating up. I checked everything out heating element fine and low pressure switch works. Just won’t circulate water at low mode.
So I drained spa because I was going to take bump out and have it checked out. But I decided fill it back up and try again. After I filled it up. Started circulating at low pressure again and heating up. Ran continuously for almost two. Got in at 102 degrees turned to high speed. And I know heater does not come on at high speed. So when done switching back to low pressure. And won’t pump anymore at low pressure mode. Just high mode. So what could be causing this? Pump just hums and then throws the dash’s and dots code.
