Corey, I wanted to thank you for the thorough explanation because a quick capacitor test. I went through control panel, sensor, transformer testing and went back to the voltage regulator and capacitors being the cause. For future readers:
Spa: 2001 Sundance Cameo. 6600-056 RevB board
Symptoms: 45 degrees out / freeing evenings. Plug in the main 6 pin power supply to the control board, temp quickly displays and is cool, single pump cycles or press the light button, display fades to white with watch dog - - - -.
By heating up the two main capacitors by the voltage regulator, I was able to get the panel to stay on and get my spa out of freezing risk temps. New caps ordered and will self serve.
Cheers!
