You can check the check valve to make sure it is clean, free of debris and not restricting water flow in any way. If the check valve is clogged or damaged, it can cause the ACE system to fail. If the check valve appears to be working properly, the problem may be with the power supply or an electrical problem. It is best to have the hot tub inspected by a certified technician to diagnose the problem.
