I have a 2019 OC Hot Tub Tranquility with a Balboa system. A few weeks ago I noticed it was lower temp, had LF code than Dr code. Water level is fine. I replaced the filter, tried to remove air from the lines(in case that’s the issue by using bleeder valve and loosening the valves. Each time I restart the system, it heats up fine, gets to temp set (101) then within 24 hours I have another LF code. If I remove the filter and run the jets, the code clears and the heater kids back on and the cycle starts again. Any ideas on how to resolve? Thanks
