My hot tub pump works on low speed, maybe not as powerful as it used to be, but when I switch over to high speed it sounds like it tries to start for a second, and makes a click or a thunk sound before cutting out. I can also only get the heat to go to about 60 degrees too. I'm guessing this is related to the high speed pump not working. I have checked all the wiring with a voltmeter, and everything is reading ok. The tub has been filled for a few months, and I ran the cycles to clear any trapped air so I don't think that should be it. Nothing looks to be blocking the flow of the filter either. The breaker never trips, and one thread I found sounded like it could be the capacitor, but that sounds like the low speed wouldn't work, but the high would, which is opposite of my case.
I'm thinking I might need to replace the pump, but was hoping someone could confirm that might be the case before I paid the money for a new pump.
Thanks for any help in advance.
1619790068_IMG_1401-Trim.MOV
