Right, thank you for that info, that's interesting. That explains why sometimes you feel this leakage on water taps outside some properties (not felt it anywhere else around my house though)
When I tested it with the electrician, under the spa was wet. It is sitting on tiles that don't drain water quickly and when there is rain or pressure washing, all the water goes under the spa before draining out to the back of the garden. This has made one side of the spa under frame timber all wet. If you connect one end of an electrical meter to the wet wood and the other to the spa water, there is a steady 5v running, going up to 10 when you turn on the jets.
So I have placed stainless steel plates under these wet areas and connected them to ground which has reduced the voltage to 0.
Eventually I will deck the area and raise the spa onto a concrete slab with proper drainage, but for now this is what I have come up with to deal with the problem. Thoughts welcome!!
