Here I was worried about taking a hot tub that's 21 years old! That makes me feel better.
I read somewhere on here that the red and blue hoses that Cal Spas used were prone to cracking. I'm replacing one of those now but I think it was due to a leaky cover over the winter and winter temps. I also had to replace a 12 port manifold. While I have a lot of foam dug out and, the hot tub flipped on its side, do you think it's worth the work to replace all hoses or should they be good to go since the hot tub is now in place? I guess my main reason for even considering it is because the thought of spending money on spray foam and then possibly having to tear it back out looking for another leak down the road. If you have original hoses that are still holding on I'll feel much better about not replacing them. Although, I'm going to replace the cabinet panels so it would be nice to know everything is solid. What do you think? Is it even worth it to replace all hoses on an older spa? Supposedly the 2 main pumps are new within the last 3 years so I have that going. I would call Cal Spa and ask but sounds like they wouldn't be able to help. 🙂
