Thanks for the reply.
The pump/motor stopped working about a year ago was the original problem. I figured I'd better replace it before winter hits again and I'm not so lucky.
When I turn on the power to the spa, there is an indicator that shows the pump is running, but it is not. I can cycle this indicator on and off, but the pump still doesn't run. I took a picture of the wiring on the original motor and duplicated it on the new motor. There are only three wires and four connection posts, so it isn't difficult to mix up.
Regarding fuses, where would I look for them? This is an ECCO brand spa, which I believe is now owned by Destiny Spas. I don't have any other information on the spa unless there is a tag behind a sidewall panel, and since my spa is inset into a deck, I prefer to not have to take apart another side of the deck if it isn't necessary.
