the mighty Q
20 -
Days Won
1
the mighty Q last won the day on July 7
the mighty Q had the most liked content!
the mighty Q's Achievements
2
Ok so I switched the black wires for the bower and the circ pump added a jumper to the pressure switch and started it up. When I first turned on The breaker A red light came on for the heater indicator light. Then water began to flow from the outlet hose from the heater for a brief minute then it stopped. The jets worked and but the heater did not continue work. I have tk pick up a voltage meter today to text the fuse. I will be send more photos so you have a better idea of what’s going on. Thank you
Nope, I have to take some of the credit. The previous told me it needed a new “program board” and showed me this picture that I will upload here. So I had a guy come install it he charged me an arm and a leg. The seal in the back of the heater had a crack in it so it was leaking water out of the back of it so I ordered and installed another one. I only installed the wires for the new heater. The breakers where constantly tripping due the incorrect wiring on my part. Attached below is the original board that came with the spa that the original Kerner said I needed to replace.
I did what you said and I got the jets to turn on and not trip but now the heater isn’t heating the water. Then jets are turning on strong and blowing well but the water isn’t coming out of the jets hot at all. It’s just blowing the cold water. Hears a pic of the board now. Let me know if you have any suggestions. thank you. IMG_2331.MOV
the mighty Q started following RDspaguy
