Hi all,
Would really appreciate some help. My 2008 Softub has an inline GFCI that is tripping immediately when it is plugged in. Assuming that it might be the issue, I replaced the inline GFCI with a new one. Still no luck. I took a look at the motherboard, and I can see that Softub designed the ground wire of the motor to be overlapping with the ground wire of the power cord (this is called bonding, I think?)
If I separate these two ground wires, the tub will continue to run successfully. If I touch the two wires together, the GFCI trips. What can I learn from this happening? I assume there is a ground fault occurring, but is it my motor? Or my power cord? edit: The white wire coming from the motor appears burnt
I assume having these two wires separated is not safe and am not currently using the tub.
Thank you
