RHeller1
RHeller1's Achievements
Junior Member
  1. are you strapping it down? maybe wind is blowing it up along with leaves and debris???
  2. Does anyone have any recomendations for a legit online cover dealer? From what I can tell most sell the same product, Its just whether or not you actually get it.
  3. my PH is at 7.6 again today. My TA is 60 now. My TA has been pretty stable. it was 70, but a few times adding Muriatic acid has dropped that. my FC is 1.5 and my CC is 1.
  4. ok, say 40, but it was right past the 40 line for CYA. I am using a 25ml for my chlorine test. I use MPS once a month. I understand pool chlorine and bleach are basically the same, thats what is bugging me.
  5. I am using the k-2006 So since my first post, I have quit using the clorox performance bleach and went with liquid pool chlorine. My PH has read 7.6 the last 2 days, my TA is at 60, my CYA is at 38 and my chlorine is at 4ppm. I cant explain this, but something in my tub does not like performance bleach
  6. using clorox performance bleach from walmart https://www.walmart.com/ip/Clorox-Performance-Bleach-121-Oz-Pack-of-4/578526528?wmlspartner=wlpa&selectedSellerId=2094&&adid=22222222228000000000&wl0=&wl1=g&wl2=m&wl3=42423897272&wl4=aud-430887228898:pla-51320962143&wl5=1025846&wl6=&wl7=&wl8=&wl9=pla&wl10=113148485&wl11=online&wl12=578526528&veh=sem&gclid=EAIaIQobChMIwpjCjOns-AIVO_bjBx0QagivEAQYByABEgLub_D_BwE&gclsrc=aw.ds
  7. my tub is 375 gallons. I am testing with a taylor. Everything your saying makes sense, except my sanitizer never tests very high. If I put a couple tbs of muriatic acid in, my ph tests 7.4. Next day the PH tests over 8 again. Only thing I am adding is Bleach, so that is why I am thinking the bleach is the cause. Thank you for the time and knowledge. It's a bit frustrating when you have all your numbers right where you want them and then only one goes crazy on ya.
  8. At a loss here. My CYA is 35, my TA is 70 and my PH is 7.4 until I add bleach. I am using 7% bleach. After adding 3-4tbs of bleach, my PH shoots to over 8. Please help, not sure what I am missing.
  9. See where the wires go into the pump? on the end of that side of the motor, right in the center there will be a dust cap
  10. great idea! now I need to find someone that has those capabilities. Thank you for that idea as my search is coming up dry. This might be my only option!
  11. On my Marquis, in standard mode, the pump turns on for 2 minutes every half hour to check the water. If heat is needed, it will heat the water, if not it turns back off. Maybe this is what you are experiencing?
  12. Looking for a battery cover for an older Marquis/Balboa remote. Remote looks like the one attached. Please let me know if you have one!
  13. Trying to figure out how to remove one of the air control valves on my 2008 Marquis Destiny. Does it just pop out the topside or do I have to unscrew it from under?
