Rxgofishing
Rxgofishing's Achievements
  1. That sounds like the problem! Because it doesn’t get hot before shutting off. I’ll have to take the motor back out and check. Thanks for your help.
  2. No buzzing noise before shutting off. It’s a single speed motor. This tub also has a smaller motor which circulates water 24/7. Unit was wired just fine. I removed wires to replace parts but rewired exactly as it was when I took it apart. I just had to remove white and black wires from their terminals and remove nut holding ground wire. Is it possible to install bearings upside down??
  3. I have a 2013 Hotsprings Jetsetter tub with a single speed Wavemaster motor. Motor was whining so I replaced bearings and seal. Put it back together and now when I turn jets on the motor runs for 10 seconds and turns off. It will immediately turn back on again but only run for 10 seconds. No breakers tripping. No air locks because when pump is running it’s like a new pump circulating water very strongly. Seems like some kind of timer issue but I don’t see any timer settings anywhere on the control pad. It ran fine before I took it apart but it was whining. I must have done something wrong. Any thoughts? Thanks.
