I Recently started using bromine in my tub and I’m having an issue keeping the Alkalinity in range between 80-120ppm.
This is my second fill with Bromine after using Chlorine for a year and a half. I never had this issue when using Chlorine.
Little background on the tub. 400 gallon,city water, ozone, circulation pump.
Fresh fill with new filters, bromine salt to build the base, 2 oz MPS, 2 bromine tabs in floater.
procedure was after the Water fill. I used dry acid to bring down the pH to 7.6. ( 4 ounces in total ) I then added the bromine salt, the MPS, and the floater. Ph then shot up to over 8.0 added another 3 ounces and then decided to take in a water sample to the pool store
currently the reading are:
8.0 ph, 62 Alk, Calcium 158, Bromine is 8.42
Now I’ve read in this form that keeping alkalinity between 50 to 60 is not a problem. However of course everything were taught says the alkalinity should stay between 80 and 120.
what’s your thoughts on my next steps bring the pH down and not worry about the alkalinity? or fight the alkalinity and pH to get them in traditional ranges?
