Hi it is a system which was installed approximately 5-6 years ago initially few years ago the water pump was replaced due to a leak and it was replaced under warranty by company who installed the hot tub , anyway last year the temperature of the tub wouldn’t go above 26 degrees even though it was set to 40 degrees was very tepid , it was turned off drained cleaned new filter fitted etc refilled and it still wouldn’t go above 26 degrees , then suddenly weeks later the rcd / trip plug was buzzing away ended up turning it off got around to fitting new rcd/ trip plug recently and turning it back on and this time temp wouldn’t go above 12 degrees so I ended up doing tests I mentioned above and then came to conclusion it’s possibly a bad relay as no power to heater and no output from pcb to the heater element etc all fuses okay, resistance of heater appears to be good and I realised after researching this system doesn’t have a pressure switch it uses the two thermistors A and B as a flow sensor aswell as high limit stat so I wondered if the thermistors were out of spec not enough to pull a fault code but I did notice the cold temp led on the top side control panel flickering!
I thought I’d try testing the thermistor,s but as you say the pump runs on low and high speed it’s just the heater isn’t working so trying to understand what else external to pcb could cause the no heat issue before condemning the pcb / relays I will test the thermistor,s over weekend , If anyone knows which is the heater relay please let me know as the circuit diagram does not specify, I might try to do a replacement myself..
anyway thanks for advice.. I will post another pic of circuit diagram and pcb board
