B.L.U.F. - everything seems to be working now! After doing the tests, I wired everything back to normal, turned power back on and after prime mode the circ pump came on and is running. 🙌
Here’s the results of the diagnostic tests:
Fuses all checked out as good
Then switched pump 2 and circ pump on the board and powered up. The circ pump came on during warm up, but pump 2 did not. However, I now realize I might not have waited long enough to see if it would come on. I assumed the circ pump spot on the circuit board was out so I gave up quickly. Then put everything back and powered up. Waited for prime mode to end and the dr code flashed for a second but then the sweet sound of the circ pump came on and it was running, dr code went away.
Will obviously report if code comes back, but with the pump running now I think I should be in the clear.
So how did the issue resolve itself?
I’m new to this all, but I have two guesses:
1) either there was air in the circ pump lines that was able to be cleared when I forced it on pressing the pump 2 button during prime mode, or
2) when I was swapping out the connections on the board, I noticed the W2 connection wire (which connects the circ pump and ozone to the RED AC bank) looked somewhat loose, so I pushed on it to make sure it was connected properly. So possible it came loose at some point..assuming that would keep the circ pump from running.
Let me know if you have any other thoughts, but truly appreciate the help!
