martijndk1983
19 -
martijndk1983's Achievements
4
What trailer to use when moving a hot tub?
martijndk1983 replied to 6010fd12's topic in Portable Hot Tubs & Spas
I recently had to move my hot tub, and I ended up buying a second-hand Big Tex 14OA-20 from https://www.boomandbucket.com/equipment/trailers, which cost me around $6000. It was a budget-friendly choice considering I didn't want to splurge too much, especially since I was just starting a plumbing installation service. It's sturdy enough to handle heavy loads like my hot tub without any promblem. Just make sure to secure everything; I use heavy-duty ratchet straps and sometimes additional cushioning for extra safety. As for the hot tub's electrical and technical parts, I made sure to disconnect everything and securely wrap the components to avoid any damage during the move. -
martijndk1983 started following hotspring envoy 2012 ace
Hello guys, I have a question, my hostrping envoy from 2012 with ace cell gives me trouble. A year ago i replaced the ace cell for the scepter, that is an aftermarket replacement cell for hotspring because the original i way to expensive i think. after a few months the displays tell me it is offline after doing the salt check it stays on the bottem of the yellow line and after a day it stop working again. There is enough salt in the water, i clean the cell every month with ph down, also i exchange the wires every month(flip them) Does anyone have knowledge of this problem of know what to do?? With kind regard martijn
What hot tub to buy if you have unlimited money?
martijndk1983 replied to Anastasiia's topic in Portable Hot Tubs & Spas
I got last month the Empava SPA3550. It's a big and luxurious one, and it's for 6 people. It has a new massage system that mimics petrissage, effleurage, and tapotement massage methods. Tried all of these, and it's a real thing. -
Hello guys My water have a to high calcium level 198ppm and I am using a salt system so It have to be 25-75ppm. I have seen the vanishing act pillow on YouTube. But I was wondering what is inside of the pillow? Maybe we can regenerate it. Or is it simpel a resin in it. What other things can I do to decrease the calcium level. Thanks you guys.
Hello guys I have seen a video that there is a service menu for hotspring, the newer models. Just curious if mine has it also. Hotspring envoy 2012. Maybe I can change the speed of a pump. I have 2 exact the same pumps but 1 is 2 speed and the other one 1. I have an iq2000 orca https://youtu.be/rM6AQOaBoLE Thank in advance
Hot Springs Iq2020 Board Jumper Settings Decode
martijndk1983 replied to Grumpy Old Timer's topic in Portable Hot Tubs & Spas
I was wondering also what setting each jumper does. -
Hello guys, The jacuzzi is up and running so now i have to concern about the water values. I have a poollab 1.0, salt and phosphate tester. What are important values, of course PH,Salt,Alkalinity,cloir,Calcium hardness. Do i miss values? In the manual the talk about calcium hardness and in the picture the say hardness 25-75ppm but do they mean calcium hardness. When i use metal clear does that also have effect to calcium hardness? Is cyanic acid also important, i use the choir that's made by ace and sometimes i use the the granules without a stabilizer in it. Thanks for you're time and help.
Hello @ratchett Thanks for your clear explanation, you give answer on all of my questions in once. The moto massage is working the jet arms where faulty so i bought new ones. And all the rest is also good, it is a pink color and i see last night an other hotspring picture and that one had it also. It is petty that there ar no drawings and scheme's for customers, i understand why hot spring doesn't want to have everyone one . But if someone read this, i am looking for it even i will pay for it. Thanks
Hotspring envoy power phases
martijndk1983 replied to martijndk1983's topic in Portable Hot Tubs & Spas
U have right it is stil 220 but then 3 times the load if you want. But I doubt if I get a benefit at all.so after a few weeks I know more. I was not clear in what I mean, thats because I don't know a lot of electricity. Thanks -
Oké, the air hose was delivered today. Unfortunately when I place it in place I see the other problem. Both of my moto massage arm have a faulty broken silicon in it. The official hotspring dealer ask 460 euro's for the parts, I told him it was to expensive because there was an other official dealer 200kilometers away that seller it for 315. He send a mail back, good luck and enjoy you're jacuzzi. So after a road trip I get them and installed them, now it is working great.
@RDspaguy I don't want to be a wise guy but look what I have. The full schematic and how to for 3 phase.Don't know the benefits but it is possible. I have it from a hotspring dealer. -
Oke, after a evening on the web i think you have it right.🤔 This hotspring have only a 1500 watt heater and with the pumps it is about 3400 i think so that is enough for single 220 and 1 phase to do everything. A lot of jacuzzis(chinese) have a 3000 watt heater and the users set it on 3 phase to do everything at the same time. I am a quick learner, don't you think😄 Only dig in the specs and think logic but without your answers i don't think i investigate it🤓. So thanks for the help, case closed. -
Thanks again, i was outside and i removed the monomassage panel and the hose was broken. The seller said that the mechanic set the stream softer for his back but i think he was lying. I ordered a new hose and fill the bad and i will look what it does with the new hose. maybe the stream is powerful enough and it was all a lie to mask the monomassage movement defect.
yes i understand what you mean but here the people do it a lot. the 3 fase are separate groups in the elctricitybox in the house. In the house are 3 phases coming in from the street. But for now i leave it like 220v till i got the other problems fixed. When i connect it to 3 phases i wil upload the board with the connections and let know what the hot spring mechanic has done. I really appreciate your help, even when we are not on the same page. Thats the nice thing about a forum, we can discuss and bring ideas in.
