Hello,
I have a 3 year old 110V, 225 gallon spa. The spa has Balboa internals with a 4KW heater and 2HP pump. The spa is connected to an outdoor GFCI outlet and the cord also has a GFCI plug at the end. So just recently the GFCI plug started tripping. I turn on the spa and it starts priming then after a few minutes the pumps lower intensity and the GFCI trips. My intuition is that the heater element kicks in at this point and trips the GFCI due to a bad heating element. My understanding is that this 110V spa is actually a 240 V capable spa and the only difference is that it is programmed by the dip switches so that the jets will not kick on to max at the same time as the heating element. This is fine for me living in FL since the heat doesn't dissipate nearly fast enough for it to cause issues.
What I have done so far is test the heating element for continuity, resistance, and voltage, I would have done current but don't currently own an amp meter and just have a multimeter so I would have to wire it in series. Anyway, the continuity test passes and the resistance is at 15k ohms. When I did the voltage test with power I saw that the voltage was 0 while the tub was priming then got to 120 V for about 1 second before it finally tripped the GFCI so Voltage drops to 0 again.
Again this leads me to believe it's the heating element and basically just want confirmation before I go buying parts and trying them when it's not actually the issue. I'm just confused since the continuity resistance and voltage across the element seem normal... other than the GCFI tripping. The only other thing I'm suspecting is that it could be the GFCI plug itself is bad and it doesn't trip unless the heater is on which overloads it.
I attached images of the spa internals for reference.
Thanks for the help.
