AshleyD17
23 -
AshleyD17's Achievements
Hot Springs Spa - D9 or Pressure switch jump issue?
AshleyD17 replied to AshleyD17's topic in Portable Hot Tubs & Spas
Sorry for any confusion. I tried correcting/clearing it up with the earlier post. My original post had the hot tub info: it is a 2005 Hot Springs Vanguard. Worked fine until relay board burnt up (which was coincidently..or maybe not? Discovered after a power outage on Christmas day). Prior to then no issues at all and I've previously replaced the heat pump and circ pumps as well as the 20V on the GFCI when I first brought it back to life about 2 years ago after it came with the house we bought. I'm re-posting the diagram from the user manual that was with it and it matches the online version identically so it is accurate. Also posting figure 1.3 which is the correct diagram that came in the directions for the relay board replacement. My original issue is after just replacing the relay board, I was getting a flashing D9 top center of relay board which from what I could find, meant the board was "bad." Didn't change any wiring at that point from the original setup just figured it was my luck that new board was a dud (saw others had this issue)..ordered another one and installed it, same thing. Resolved that by replacing what appeared to be a damaged connector on my red wire from motherboard..no more flashing but now I'm where I'm at now with no power to H1 or H2 even though all lights are correct internally and no errors, etc on display. Hope this clears it up! I really do appreciate all of the help you all have provided. (Last pic is inside cover from iq2020 box)- 43 replies
- no heat
- iq2020 jumpers
I posted earlier the correct one..sorry this one came back up from earlier on in troubleshooting. Here's the correct one I reposted about 5 hours ago. Sorry for the confusion- 43 replies
- no heat
- iq2020 jumpers
Ahh yes should have mentioned its back on 18v. Sorry got leaving that info out- 43 replies
- no heat
- iq2020 jumpers
Alright moved the wire over. Here's what I get now 1st (white) and empty 120. First (white) and 3rd (black) 120. Empty and 3rd (black) 241. Fun fact..now the very original issue I posted about D9 flashing red on top middle of new relay board is back to flashing and still nothing on H1 and H2. Time for an electrician?- 43 replies
- no heat
- iq2020 jumpers
Going to try moving black wore to open term now. The test results I posted right before this was prior- 43 replies
- no heat
- iq2020 jumpers
I'm new to testing this thing so bare with me. If I put it on the first circled (white) and second circled (black) I get 120. First circle (white) and third circled (empty) I get 120. Second circled (black) and third circled (empty) gives me 241. Is this what you mean?- 43 replies
- no heat
- iq2020 jumpers
Let me try adding some new pictures where I'm currently at. Everything is off at the main right now so disregard the breakers positions for pic purposes. I think I may have originally attached the wrong diagram from the replacement relay board. Note also this is how it was wired before I switched the board. Doesn't mean it is right (by any means) but everything worked that way for a year. I really appreciate all of yalls help! (First diagram is from user manual and 2nd is from relay board replacement instructions)- 43 replies
- no heat
- iq2020 jumpers
Alright guys getting closer (I think!) When the new board came in it was set to 18V. Nothing said to change it to 12V so I left it. Read something on another forum last night that said if I went from the 3 relay (old) to the new 2 relay to try the 12V. Just did that and this is now what I'm getting... Still nothing on H1 and H2 BUT now I'm getting 122 at 1 and 3, 244 at 2 and 4, and 122 at 2 and 5. Not sure if it matters but showing 244 at 3 and 4 and 121 at 3 and 5. Added the missing screw as well on the leg on the 30v at the breaker (it wasn't there before but just in case). Still can't understand H1 and H2 though ...literally 0.- 43 replies
- no heat
- iq2020 jumpers
I'll check out missing screw. They were off in the picture I just took that for reference when I was working on it. Thanks!- 43 replies
- no heat
- iq2020 jumpers
Well made a few switches and still 0 for H1 and H2 but for all the other ones you told me to test..now I get 120 at 1 and 3 and 1.3 for all of the rest- 43 replies
- no heat
- iq2020 jumpers
Likely a dumb question but figured I'd ask since my colors on my wires don't match my diagrams..the neutral. Would it be the one that's grouped with the 3 wires (red/white/black) or would it be on the other set of 2 wires that are grouped together (black and white) most likely? Pretty sure my ground wire is grouped with the 2 set (white and black) if that helps at all...- 43 replies
- no heat
- iq2020 jumpers
Yep appears that way. None of the breakers trip or anything either so I don't know what changed. Everything turns on, jets/waterfall work and I have bubbles out of the bottom just no power to the heater (even though it too says its on). Didn't make it outside to mess with it again today but I'm going to go back to square one and just try rewiring everything based on the wiring schematic that came with the new relay board as opposed to the hot tub manual. Only thing else I can think to try before I call and wait on a pro I live in the middle of nowhere so fingers crossed because I already know it will take forever to get someone out here (if I even can!)- 43 replies
- no heat
- iq2020 jumpers
- 43 replies
- no heat
- iq2020 jumpers
Ok this is what I've got: H2 and H10 still 0, 1 and 3 showing 1.3, 2 and 4 now showing 0, 2 and 5 showing 0. At a complete loss as wires exactly as it was before I changed the relay board out- 43 replies
- no heat
- iq2020 jumpers
Test post. Keep getting an error message on the forum when trying to reply please forgive me if this is a duplicate- 43 replies
- no heat
- iq2020 jumpers
