I thought I would assist in resurrecting this post with the following:
I just read an old post where you were looking for the same information (Below) I am seeking today. Did you ever discover anything? We have a 2012.4 HotSprings Jetsetter with the Orca IQ2020 system with a topside LCD (Had no luck locating a replacement) that has failed and have buttons only now, which is still usable but I am looking to change the programing to allow the heat to stay on with the jet pumps. It was setup that way before we switched it to 230V. I would also like to have wireless control without having to build and program my own controller. Watkins swapped over to another Controller and the Topside is no longer compatible with the previous controller.
I’m not really apposed to buying and programing a Wireless PLC 4 way switch, which would make it very versatile. My thinking is if I am going to build something, I want to go all out. I would like to add the SPA via an Arduino/Raspberry Pi, Wireless Receiver, Relays, and Contactors for high current like Pumps and Heat to our Home automation system. Then program it to calculate the most efficient temperature to maintain knowing variables like the local weather forecast for temperatures and unfavorable conditions. It would have access to my calendar and my current location as well as when I planned to use it by placing it on my calendar or voice command to Siri. Then it would heat the tub before I planned to use it. I know it sounds a bit over the top, but it would be pretty cool having the porch lights, music and tub ready when I arrive home.
Right now I would like to find if I can access the programing via Serial or SSH since I have no LCD to change the factory settings, which need the display as published.
Anything you or any one else has discovered and would share would be greatly appreciated.
