The HL error code is 100% the thermostat, Ive changed 3 now. They are in the flow of hot water which rapidly reduces their lifespan. I relocated the last one I changed because I was fed up changing them, they’re very cheap, but it’s a time consuming job. I soldered the new one on and then led it out of the pipe that the hot water comes out and sealed it where it used to come out, problem solved, just put the wire and thermostat in the filter sock. Next time it stops working I can solder a new one on without even emptying the tub.
