Brand: Hot Spot
Model: Dash
Built: 2010
Observation 1: Opened cover, not running, water lukewarm, tub full, panel reads "FLO".
Response: Pushed button once (hi jets), makes humming sound. Pushed again, lo jets come on (as they should). Turned off jets, removed filter. Pushed buttons again, same result. Turned off power at breaker, reset, shows temp (95 degrees), push buttons, same response. If left on first push (hi setting) will eventually click, stop humming, and FLO code reappears. Turned off power at breaker, cracked open various fittings, determined water is flow through system. Refilled tub with water, turned breaker back on, nothing changed. Let run on lo setting, water never heated up (still 58 degrees), about 30 minutes later blows breaker. Reset breaker just to check progress, still runs on low only, 58 degree water. It has sat with the power turned off at the breaker for a few days now.
What to do next??? If there were a tech or dealerhip available in my area, I would totally call one - but there isn't. I have read some posts that talk about getting a multimeter and checking all of these various circuits, which is within my skill set, but I wouldn't know how to fix that type of problem even if i found it.
Sidenote: I have lived in this house two years. About a month after moving in the circulation pump went out. I ordered a new one and replaced that on my own. The previous owner left a new heater unit ("S-Class" blue plastic box about 12"x12"x4" with cylinder underneath and mounting feet brackets - looks exactly like what is already hooked up there). I am not comfortable hooking this up (there are too many wires that go too many different places), but there is a semi-local sometimes electrician I could get to do that piece.
Thoughts?
Much appreciated.
