Howieleem
  • Content Count
    2
About Howieleem
  1. Hi. Located in uk. The heater has as you say 2 x cutout relays, one on the live connection and one on the neutral. One is a 50 deg temp cutout to protect from hi temp damage, the other looks like a hi current trip. Before putting new heater in it measured 18 ohms across the two element terminals with no connections to it, and infinite resistance between either of the terminals and the body of the heater. So all ok resistance wise. Fitted heater and started system. Water flowing ok and the heater getting hot. After 30 seconds system stopped. Measured element and it is now open circuit (inf
  2. Ive had a problem with the bilbao heating element burning out. I think i may have wired it with the live and neutral on the wrong terminals. There is a 50 deg. cutout device on the live connection which i have had the neutral connected to it. If the live is still connected to the element after the neutral is disconnected by the 50 deg cutout, will it burnout the element?
