xwaveone
  • Content Count
    1
1 Neutral
About xwaveone
  1. There is a lot to your questions to answer and I will be brief. 1) VS501 has plugs for 2-speed pump 1, 1 speed pump 2 (that then uses the blower receptacle) and a circulation pump. When circulation pump is used, the setting to have pump1 function in both speeds, has to have both A5 and A9 dip switches ON. The circulation pump will then run continuously with 3 deg F setback. 2) BP501 as it comes from the factory comes only with a 5.5kW heater. To install a 4.0 kW unit it would have to be a field conversion. For example we can do it. Whether an E14 will work with M7 spa pack equipped with a
