We moved into a house recently that has a hot tub in the basement. This is our first time owning a hot tub and I had no idea what to do. The previous owner left some chemicals behind, so after a little research I bought some test strips (after a lot of research I realize this is a no no) and attempted to balance the water. We used the tub for about 6 weeks, water is clear, doesn't smell, filter has been rinsed and is very clean since it's indoors. The tub has a bromine floater and I've been shocking 1-2x/wk. All was well, although it was very difficult to tell with the test strips if the pH was correct (so maybe it was off?)...until last week when I got a nasty rash that just keeps spreading even though I haven't been in the hot tub since. I did notice not too long ago that there was some yucky stuff building up on the seam of inside of the cover so I just wiped it away with a Lysol wipe (bad idea?).
So...I've read Nitro's decontamination method, figure that's the best place to start from here. Questions:
1. Do you leave the cover on or off while going through all the steps?
2. How often am I supposed to clean the inside of the cover? Can I just use regular cleaning products, or what do you recommend? How often should this be done?
3. I've read some posts that say 'brush the spa'? Is there a specific brush you need, or anything soft-ish will do?
4. I have a water softener. Some things I've read say to use the hard(er) water, pre-softener, to refill, others say a mix of softened and not. Thoughts?
5. Draining...because it's indoors, there is a hose connected underneath that goes into a drain. I have to assume this is going to my septic system. From what I've read, people who have this issue suggest cooling the water and draining it bit by bit over a week so it doesn't flood the septic. I assume this will begin a bacteria breeding process again and ruin my decontamination. Ideas?
6. Testing -- I have read here that the Taylor kits are the way to go. I can't find a 2006 bromine kit in Canada. Someone suggested a 2005 and doing some calculations. I found it on amazon for $158 which seems pretty steep given it isn't even what I need. Any other kits available in Canada that will do the job? I also have a saltwater pool and will need a kit for that, so if there is something that could do both that would be amazing!
Sorry, a lot of questions. But I have read A LOT and still feel so lost. And I really don't want anyone else in my family to experience this nasty rash that I am dealing with.
Thank you in advance!!
