So I am new to having a hot tub, we bought a cheap used unit that was supposed to work great. I ran wire, hooked it up to the Balboa Value 2000 system, ran it to my panel and hooked it up wrong on the breaker. I know I know I just didn't pay attention. It is a GFCI breaker I ran my white wire to the ground bar, then put he wire from the tub to the same spot on the breaker well it turns out that was supposed to be a hot (red or black) wire then I put the red to the white spot. It supposed to go red white black. I turned the breaker on the display flashed for a split second then nothing. I found my mistake, corrected it. Checked all the fuses I could find on the Balboa system and they all looked fine, I tested the ceramic fuse and it tested good. The system does nothing. Nothing comes on the control panel. The tub is still empty so is there a system in place to prevent it from running without water? It is an older Catalina Spa. Did I likely fry my board?
