Michael M
Michael M's Achievements
3
  1. Update. I took the circuit board out and removed the two relays that were connected to the heater. One of them was stuck closed. I ordered 2 new relays and will hopefully have them back in the board in a couple days. Thanks for everyone's help!
  2. Here is a picture of the board that matches mine. I will have to label and remove all the wires off of mine because with all the wires you cant see the board clearly. I cant see the back side until i remove it. I am suspecting the relay(s) might be the two with the jumper wire going in between them as they would be closest to the heater but that is just a guess. Looking at this board and mine on the tub the only labels are K5 and K6. Thanks for your help!
  3. Is there an easy way to find out what relay could be bad?
  4. I have removed the filters, Set the filter cycle for 2 hours. No matter what i do there is power going to the heater, even when i set the temp below the current water temp. Does this sound like a bad relay? If so can i replace it or do i need a new board? I am ok with my soldering skills LOL. Thx!
  5. Reading in my manual it states "Your system has a 24-hour circ pump. The circ pump runs continuously. The ozone generator runs during the first half of each hour, except when the ozone generator turns off for an hour due to the Therapy button being pressed." So i dont think i can run it for 2 hrs at a time. It is a LEGEND SERIES CONTROL LS800
  6. Thanks for the info. I will try that and let you know what happens!
  7. Hello I have a Master Spa with a Balboa MS8000 Circuit board. Everything seems to operate absolutely fine with the exception that it keeps overheating. The temp goes up to like 110 then i get the OHH error. I can turn it on the next day and the temp just climbs all the way back up and shuts down again. I have checked the water temp with a thermometer and it matches the temp on the display. Does anyone know why this could be happening or what i could check? is there a relay or something on the board that could be causing this or is there a different thermostat or something that isn't working? Any suggestions would be great!
