Hi, I am in the UK and have a 2016 Serenity 4000. It has similar symptoms to other problems in this forum, but I have started a new thread as recommended. A few months ago, following a short power cut, I noticed that the tub had not re-started and seemed to be in a control loop about every minute or so where it would almost go, the pump would try to run for a half second or so, then the top panel would reset and the cycle would start again. If left, the tub would eventually go, and when it had got through the initial check/test/high speed run phase, it would run for weeks without any issue until the power went off again.
The situation has deteriorated recently, and the tub will not get past the cycle as above. I have added a video of the symptoms, which includes 269/r2/LL1/attempt pump start cycle.
There are 2 other points that might be important. If I unplug the top controller from the main panel inside the tub (presume the 'Spa Pack'?) the pump will run immediately for about 16 seconds at high speed, then stops for about 7 seconds and then starts again. Every now and again, the pump will not quite catch and it will be the half second pulse, but it generally will catch on the next cycle and run for 16 seconds again. As soon as I plug the top controller back in, wherever it is in the cycle, it reverts to the fault cycle 269/r2/LL1 as described.
The second observation relates to what happens when the tub is competely powered down. To protect the system from all this pulsing, I switched the tub off at the breaker and left it a week. When powered back up, the tub appeared dead, but the LCD backlight could just be made out to be on. Over about 30-40 mins or so, the LCD would slowly get stronger and readable, and the 269/r2/LL1 cycle would be visible, but with no clicking or pump starting. After many hours, the fault cycle would start to include the pump pulse that can be seen in the video.
I have checked all fuses and connections, all good, and I am happy to pull the thing apart to look at the circuit board etc and check for damage, if that is the recommendation. I am holding off in case the description above will give a definitive diagnosis in which case I can try and order some parts.
Grateful for any advice you might have.
Eric
672164993_faultvideoApr21.m4v
