Before the freeze in Texas a few weeks ago, I "winterized" my pool equipment by removing the filter, pump, and heater "plugs" and drained the system. After the freeze, I replaced the plugs, primed the pump and started up the system. Everything works, except the Jandy JXi gas fired heater took 4 hours to heat the spa section of the pool from 68 degrees to 104. The heater never cycled on and off; it ran continuously until the temp was reached, and then it shut off. Before the freeze, the spa heated to 104 in 30-40 min. What could the issue be, and how do I fix it?
Show less
