Ok.. sorry for the delay in responding.. I am also dealing with computer issues.. so that has drawn my attention away.. anybody experts in that out here?🤔😛.
Anyway, yes I believe my Taylor kit is the 2006.. I got it from leslie's so it isn't labelled, but says 'complete (fas-dpd) chlorine.. it has drip test for fc.cc.ph.ta.ch.cya. unfortunately I didn't not have the salt component.. I just use strips.. I should probably purchase that for better accuracy. And yes I use 25ml sample.
I do feel the bleach affects the salt level as it is the only addition that could be the reason it goes up?
The swg cell is freshwater brand.
Just so perplexed how water is clear but continues to eat chlorine.. and the cc level isn't high? Even if the salt cell isn't working, shouldn't the tub be able to retain fc if there is no load and the lid is closed so no sun breakdown?
So on 1/27 I doused it with 3c bleach.. the fc spiked, but was only 14 after 1 1/2hr.. which the 3c according to my calculation should have drove fc initially to 36ppm. At 9hr out it was down to 6.2. Today it is .2 or less.. and no one has been in it. Cc is also .2 or less. Other values are: pH 7.5, ta 70, cya 90 (I don't know how that got so hi! I think I must have misread it at some point and thought it was low so added some doses of dichlor), ch 80, salt 2000? (Test strip so limited accuracy). I also added borax during the startup but I don't have a test for that level.. I added 2 1/2c.
I appreciate any insights. I am fairly new to this.. have only done 2 total water changes so far. I am keeping a spreadsheet trying to track these values and my actions and gather load etc to hopefully come up with a plan by seeing how my tub behaves given the factors of our use etc.
I have looked up information here of course, but if anyone has specific links to recommend for a saltwater tub set up and maintenance that would save me search time 😁.
If seeing my spreadsheet would help, I can try to figure out how to link that here.
I think I need to just do a drain and refill, but it is so cold now. I expected this water to last longer.. the bather load has not been excessive at all
