Fingerstank
Content Count
18 -
3 NeutralAbout Fingerstank
Rank
Junior Member
- Birthday 10/03/1965
Gender
Ontario Canada
Hanging out with the kids and playing video
games : )
Hi everyone. Was gone for about 2 weeks and left the kids in charge of the Tub. Before I left the water was perfectly balanced. Came home last night and went and got my water tested at two different places today. Alkalinity dropped to under 18ppm at one test sight and 70 p.p.m. at another. Was originally at 130 before I left Ph seems relatively in line with each other 6.4 and 6.7 respective of each other. Was at around 7.6 when I left. The concerning thing is they both tell me the Stabilizer levels are above 150 ppm but under 165 ppm. 1)
Total newbie. Controllers/pacs/whatever you call them
Fingerstank replied to PoconoChris's topic in Portable Hot Tubs & Spas
Am I in the wrong forum ? lol -
Has anyone created DIY spa booster seats and head rests
Fingerstank replied to Amy5687's topic in Portable Hot Tubs & Spas
I would suggest highly not putting sand in your hot tub. Even with a tight fit and enclosed in a bag, if that were to pop open accidentally it's gonna be a hell of a mess. Just my 2 cents -
What spa ? Very vague info
Are you testing properly? I couldn't imagine the Taylor Kit being that far off from the truth, unless you are not testing proper.
Fingerstank started following waterbear
Don't forget to Nuke the tub.. Get your Fc up there above 10 ppm minimum. Before draining your tub. As @CanadianSpaTech suggested try and get as much of the water out of the tub. If you have a shop vac use it. Either reverse the nozzle and blow out the lines or suck it out I usually use the shop vac and have it suck out each individual jet as well as the filter cabinet. I make sure there is nothing left in the plumbing
New to hot tubs, possible silly question
Fingerstank replied to James69's topic in Hot Tub Water Chemistry
I am guessing from the pictures on your test strip bottle you meant to originally type out TA @80ppm Just a guess though -
Do you have a filtration timer on your spa? You could just bump the filtration up too a 24 hr period. Let it run until your under 10 ppm of Free Chlorine as @waterbear suggested. Remember after getting that FC up that high on you Nuking the Tub keep your lid open not just half the lid but open the whole lid. I have seen people shock with a partial lid open still can damage your cover even if it's only for a few minutes like that ( Obviously after several times )
It's quite possible like you had mentioned in an earlier post, perhaps the original tub owner never really took care of it? Could be the reason he sold it as well. Water chemistry isn't my forte either can be frustrating It may be very well it's finally getting a long awaited purge and stuff is still becoming detached from the plumbing and heating elements. Perhaps just super chlorinate it. Then do a complete refill and use it for a while and do it all again after you have used for a while. Thinking as long as you are keeping up with the FC levels you should be ok.
That just means it can be used in a High Efficiency washing machine eg: Front End Load Washer Just an FYI
Thanks again
Okay thanks for the input. So it's okay to use the EcoPur system either way if I do decide to switch into the Dichlor and Bleach Method. I will try it out on the next water change or I will just check out my water chemistry over the weekend and see if I can go that way now. Thanks again
Spa Will Not Hold Set Temperature – Make sure you have the heating mode set properly. Many Cal Spas have 3 modes. Change these settings by pressing TEMP followed by LIGHT buttons. All 3 modes will rotate. ST: Standard – Spa will heat to set temperature, and maintain when heat is needed. This is the default setting. EC: Economy – Spa will heat ONLY during filtration settings. It will heat to the set temperature and the spa may cool down until the next filtration cycle. Heating will resume again in 12 hours. SL: Sleep – Similar to EC mode, the spa will only heat d
Thanks for the reply @RDspaguy. I do realize the Eco pur charge doesn't replace the chemical sanitizer. I have however noticed it never has really reduced the demand on the chlorine as it's apparently possible according the MFG but obviously that may not be attenable in real world scenarios as every user has there own mileage So I guess what you are saying in a nutshell is that it doesn't matter if it's in the system or not while using Nitro's method? Just thinking of cost between the Eco Pur Cartridge cost and then again for the outer filter as opposed to just needing to purchas
