Hi there, I'm new to this forum and looking for some direction on an issue that seems to be unique to what I've been able to find so far.
I have a waterway executive 56 3hp pump for my old Sundance spa. It sat for a while over the summer after a move and the motor shaft rusted and caused some problems. After replacing the seal, impeller and motor bearings, I have yet another problem - the low speed doesn't work unless you give it a bit of a spin. High speed works fine. This motor has a start winding vs the start capacitor. The starting switch in the motor operates properly (both mechanically and electrically). I have checked the resistance in the windings and I do not have a short or open in the start winding. And when testing the resistance and manually moving the switch you can see the start winding resistance drop out.
So, any ideas on what direction to go with this thing would be greatly appreciated.
Thanks
