Hello all, my name is Peter. My wife purchased a swim spa back in June and it was delivered about 2 weeks ago. I have just completed the electrical and the water is warming as we speak. I live in Canada, so it is taking a long time to warm up the 1900 odd gallons in the tub. I did the electrical myself and had an electrician check it out. I found it very difficult to jam the larger gauge wire required into the heater box, which seemed already quite full. It's all done now and working fine, so I will quickly forget all the swearing. 😉
I would love to hear from others that have a similar Swim Spa. It came with the "upgraded" insulated covers, which seem like average hot tub covers to me. I have had a hot tub as well for about 20 yrs. We just got rid of it. I have a few questions and maybe I'll make a list.
1. How long does it take to get up to temperature? The water was about 43 degrees when I filled the tub and it is taking a long time to warm up, for obvious reasons. So far it has been about 16hrs and it's sitting at about 58 degrees. So far about 1 degree /hr. Is that normal. Looks like it'll take about over 2 full days to get up to temperature.
2. It was recommended to not have anything around the spa within about 3'. Even a deck. The spa itself is about 5' high to the top edge. I have to come up with some way of getting in and out. Obviously stairs would be the easiest but considering a deck around one corner. I will build it to be able to remove a section to get at the controls, if needed. I would like to hear from others as to how they access. Did you listen to the warning or put a deck all the way around? I'm a little stuck now as it is in the middle of the yard. We were going to do hardscape around. I'm thinking small deck at one end at corner with small steps up to get in.
3. Covers - I have had hot tub covers prior and am always angry when the cover starts to get heavy. Have there been any solutions in this area lately? Why can they not make a type of foam that does not take on moisture? Is it purely to sell more covers? They are getting more and more expensive every year, it seems. Currently it will cost Can$2000 to replace my covers. I am not looking forward to this. How long will they last?
3a. Has anyone looked into or purchased the hard shell or Covana. We looked into Covana but it was going to be Can$16K to start. Apparently the hardshell can be had for about Can$10k. That is more reasonable if it would last 20 yrs based on the current rate of hot tub cover degradation.
3b. Cover lifters - Does anyone have recommendations for cover lifters? The Spa place recommends the Cover Valet Pro at Can$500 a piece, I'd need two. See attached image.
I would really like to enter the spa at the end. The problem with that is the lifters all seem to be in the way. Are there any options for lifters that may not go to the end. I was looking at the roller system and possibly mount them on the back side of the spa. That would solve my issue but it is not the recommended location to mount and also the salesperson did not recommend the rollers. Possibly because they were about Can$300 cheaper than the other lifter.
I think that is about it for now. Any other tips and things to be aware would be greatly appreciated. Looking very much forward to being in my Swim Spa soon. I may have to wear a wetsuit though. 😉 Thank you.
Regards Peter.
