Hello
Thank you for your helps . It appreciates
@RDspaguy @CanadianSpaTech
Sorry for misunderstanding , I specify as below
It burned again after replacing two elements
- UV lamp (including power supply )
- Pack including heat
And yesterday we changed the last one in relation with fuse F2 the Pump3 and we are waiting .
We don’t have the F2 failed with the last change.
Question : And it only blows the fuse when all of the pumps are on ?
Question : How long are the pumps on before it blows?
Answer => It happens when we started P1 and P2 and finally P3 but not all the time. And we don’t know if the fails it’s in relation with P3 only.
For example when I test :
I started P1 (speed2) , P2 (Speed2) , P3 ( only one speed) many time (10 times) but F2 didn't failed
And sometimes when we did the same things the F2 burned.
Is it possible that it comes from my electrical installation ?
No breaker is trigged .
My electrician told me not.
He has verified two times the installation and for him , it’s okay.
- External Electric Panel for Spa (gfci breaker 60 Amp)
- House Electric Panel for Spa ( breaker 60 Amp)
"The only thing I can think is a check valve leak on the ozone"
I don’t where is the ozone and valve .
I am going to search the ozone module
As attached one picture.
Thank you
SPA (1)(1).pdf
