BigPaus
12 -
BigPaus's Achievements
1
2012 Jacuzzi J-200 series replacement parts
BigPaus replied to BigPaus's topic in Portable Hot Tubs & Spas
Just wanted to let you know, this did help tremendously. Luckily they are somewhat common CMP jets and I found most in stock at the store in London, ON and they sent them over right away. Swapped and boy does that make a difference! Appreciate the help. -
Hello, I am looking for a list of parts and their parts number for the Jacuzzi J-210 specifically. I am having a hard time specifically with jet. I have a lot broken and need replacement. Based on my searches so far I have to measure each and it seems there are multiple options. Is there an easier way to tackle this? I would like to just replace them all so I was looking for a list of how many of each size I have and corresponding parts numbers to just search and order. Thanks
Hi all, Looking for some help on items to use to create as much as a mouse free hot tub as I can. We took ownership of this hot tub about 3 months ago, after some initial wiring issues, I got everything solved and it's been running flawless now. I cleaned out the motor/control board area as there were some items in there to deter mice, but they have since deteriorated (mouse poison in tin bowls, steel wool, and some dryer sheets). From my research so far, I've cleaned out all the poop, nibbles from the tubs foam and put in a more potent poison for now (brother in law is a farmer, so I get access to a bit better stuff there). I would like to spray more foam in there and I am wondering if I can just use general 'Great Stuff' or do I need to use something more heat resistant? Fire rated? Next I want to use peppermint oil - does anyone have any experience with this working, how long it lasts or anything? I can't find any info other then it's a good idea to deter them. I believe they are coming in through the access panel, so I going to look at sealing that a lot better as well. Any help is much appreciated!
That is definitely a key contributor right now - it does show a lot of out of stock for a lot of things I've browsed through. If there is a physical store in London, that would work as well as we travel there a couple times a year for sure. Coincidentally, next weekend for some Columbia outlet fun during a pandemic.
I'm just outside of Stratford, Ont. I have been supporting a local store in town who took care of my pool prior to my ownership as much as I can - they actually have had decent prices as well which is good. Not sure on ordering parts though. hot tub store is a bit cheaper then the one you quoted - but service is everything and if they are better I will look at trying them out. I did remove a good amount of steel wool from the bottom of the tub casing that was rotted - so I will be replacing that.
Yes lots of mouse droppings. I've cleaned most out, and the bugger(s) have devoured about 3 packs of poison now - so I need to find something else to block their entrance. The wires all seem in good shape however. I found this site for parts from Jacuzzi themselves. Seems like decent prices as I was looking to replace some of the jets that pop out upon start up. https://www.hottubstore.ca/products/temperature-sensors?_pos=1&_sid=36423a4c8&_ss=r&variant=32120843501638 However, it looks like I may have a different sensor connection type as neither one of those match what I have? Unless I need to take the curled fingers out of the connector itself?
I was thinking a loose connection as well. Unless the sensor goes when it gets 'too hot' example, when the cover is on?
Edit. Code came back. Not sure when though. Wife said she saw the temp at 100 so she put the cover back on a couple hours ago and now the code came back. so I opened the panel to check the connections and it came back again to 100 and working. Thoughts? I also checked the voltage and it was 13.9 on the yellow wires
So I spent the lunch sitting there and has you said, it's a big pain in the you know what. I wasn't getting consistent readings - it would spike to 13.xx but then drop to 0 on both sides, so they seemed only consistent in that sense. I plugged it back in and turned the breakers back on to find the panel reading temp! It now shows 104 and I set the max temp to 100 to see what it does but it seems all it needed was the unplug and re-plug back in. Not sure if this will be a problem in the future or it says the sensor is going and I should look at replacing that. Now to figure out chemicals on this thing so we can use it. Thanks again for your help, I will report back here if anything stops working.
I do have one. Not a lot of experience using one but if I’m told what to do I can get readings haha. Here are the three pics requested. I went to the local jacuzzi store tonight and they had no clue. They thought maybe the board was a non jacuzzi brand but it was apparently replaced by them a couple years ago. He didn’t look into it to confirm though. They thought it might be a reset needed for the UV system. However I just tried the steps and the code above did not go away or change whatsoever.
The only thing odd about this was that it was throwing this 'code' before the temp got to that point. So no one has confirmed this. But if it goes into watchdog mode, doesn't that mean the jets, lights, any functions shouldn't work and it should shut down the whole thing? It doesn't do this and functions still without any ability to change temp, or show anything on the panel. Also, I had the breaker turned off for over a day and tried it again when the water was cooler - but the same code appeared. If it is a hi limit issue - what am I looking to replace or look at to confirm?
Hi all, New to pool/hot tub ownership as we just bought a home with them. The pool was closed for the season just before our move in, but the hot tub wasn't as we wanted to use it. The previously owner stated it was not filled up as he was injured and not able to use it, but that it works. He also mentioned that the circuit board was replaced in the last couple years (he only owned the home since Sept 2017). So, I purchased a filter for it and got some flush agent and filled it up. First problem I had was the breaker tripping. However, I believe this was normal since it's been off for a while and it does it as a test possibly when turning back on. The next morning I switched the breakers on and the tub showed 'ICE' and '53'. About 5 minutes later it showed '55' so I knew it was heating up. Great!... I then added the flush agent, it foamed through the system. Right when it went through a couple cycles, I noticed the code on the panel changed to the attached image. The jets work, the water feels warm (thermometer showed around 108 at the most, with the cover on) and nothing seems out of order but I cannot seem to function anything, it just stays on this 'code'. I am at a loss, and I've taken this image and symptoms to my local stores and they are confused as well. So I am wondering if anyone has ever seen this, and what it means before I bite the bullet at call a tech. Thanks
