So I recently purchased a new 225g spa, it came with the Frog @Ease system. We didn't care for it / could never get dispensing to be consistent either poor water quality or harsh chemical effects. I purged the system after the freebie cartridge ran low and started anew. I've been doing my own regiment now for almost a month (9/28). After much reading I opted to go with trying the Nature2 mineral system and MPS as my oxidizer with this new fill. In the process mistakes where made... I misunderstood the relationship between the MPS and need of Chlorine. I had this understanding that you could substitute the Chlorine with a Non-Chlorine product. I quickly learned I need to activate the system with Dichlor, I was like ok that's just an activation... I then went on to use the spa with a weekly test practice and dumping my MPS as a form of shock the following week (😰). Needless to say the water quality went south quick and I knew something was off and began digging. Fast forward to now after shocking the system properly with DiChlor and getting parameters back in line I'm questioning the whole aspect of MPS vs going straight Chlorine given my false understanding. That said, In the interim I wouldn't mind giving it a fair go for a bit now that I have a better understanding (I hope :P) of things, not to mentioned already having purchased products. But what brings me to this post is my FC value, I tested it a few times today with mid day being at 12.2 and this evening being at 10.0. I was thinking that was way high given the ideal value of 2-4ppm (from Taylor K2006) but then I noticed in nitro's post HERE stating to use Dichlor to continually raise FC til 34 then swapping to Bleach, this is obviously much higher than 4ppm. My test kit's limit for FAS-DPD testing is limited in range from 0-20ppm for FC, so now I'm totally confused. I could really use some help as I feel like I'm hitting information overload and not knowing which way is up anymore.
I do have the Taylor Deox Reagent for MPS testing, while it involves a good deal more drops I would like to continue to use that system a bit longer to see how it goes, maybe 4 weeks putting me at least to the 2month mark on this fill. Then or thereabouts I'd like to swap over to the Dichlor/Bleach method but I'm not sure If I would need to do a system flush early at that point to see how things are absent of MPS all together, especially on the testing side. I'm still somewhat dumbfounded by the MPS needing Chlorine and trying to wrap my head around what's the point then of it...
Here are my latest test results 10/13:
Temp 99d
TA 90ppm
Ph 7.6
FC 10.0
CC 0.4 (waiting to see if this falls further after early day shock)
MC 3.0
CYA 30ppm (as of 9/28 - not retested today )
CH 140ppm (as of 9/28 - not retested today)
