J365 Jacuzzi
12 -
J365 Jacuzzi's Achievements
1
2015 Jacuzzi J365 Circuit Board Question
J365 Jacuzzi replied to J365 Jacuzzi's topic in Portable Hot Tubs & Spas
Thanks for all the help!- 23 replies
- 1
- circuit baord
- spa
It looks like there was a change in the chip style between the models of board. My tub has circuit board 6600-293. Later model tubs used an updated replacement board 6600-297. One of the differences appears to the type of chip used. On my board the area behind that chip appears somewhat discolored. Wondering if that contributed to the snubber blowing.🤔- 23 replies
- circuit baord
- spa
- 23 replies
- circuit baord
- spa
Ok, so I pulled the board out and took some photos of the back. There's an area that seems somewhat discolored but not sure if that's normal. Any idea what this section of the board is responsible for?- 23 replies
- circuit baord
- spa
Here’s a photo of the rest of the board. Pretty crowded with wires. As of right now everything. Seems to work fine except the flow switch. I have a replacement coming for that. FL2 (stuck closed) error when plugged in and FL1 (stuck open) when I power the tub without the switch installed.- 23 replies
- circuit baord
- spa
- 23 replies
- circuit baord
- spa
- 23 replies
- circuit baord
- spa
Install was about 5 years ago. This past spring we noticed our interior breaker fouled and needed to be replaced. I’ll dig around online for a replacement. I found a couple pieces and “reassembled” it to reveal some numbers.- 23 replies
- circuit baord
- spa
Thanks! I’ll take a thorough look. Any idea what the specs would be of a replacement? Here’s another photo showing what may be some charring marks around those similar power lines.- 23 replies
- circuit baord
- spa
This is the board without cables and I don’t see anything that resembles that resistor on here. 211CE568-730A-4450-ABF4-60C3BDD08CC6.webp- 23 replies
- circuit baord
- spa
Thanks, do you happen to know which component? I inspected the board and schematics I could find and there’s no indication of where that part came from. The board is still clean and the tub works fine. I have a replacement flow switch coming to address the FL2 error.- 23 replies
- circuit baord
- spa
Hello, Wondering if anyone can help me identify what this is. Recently had an FL2 error code on my spa and while inspecting the wires behind the panel I noticed some charring in an area towards the bottom of the control box. This was lying at the bottom of the box. The tub seems to work fine other than the FL2 error and I can’t find anywhere on the board where this would have come from.
- 23 replies
- circuit baord
- spa
