Brian Slone
26 -
Brian Slone's Achievements
1
Thanks, I may have to do that, backyardplus does allow return but with a 20% restocking fee. Question from your previous response, you said nothing will run with the control panel unplugged, are you sure the circ pump shouldn't run? I am pretty sure it ran when I replaced the board and had the control panel ribbon plugged in backwards initially. Is there a fuse on the board for the circ pump that you know of?
I have a Hot Springs Prodigy H hot tub. I replaced the IQ2020 board, Circ Pump, and Aux Panel about 4 months ago and it has ran great ever since. But I just drained and refilled it, when I turn it on the circ pump started running but bubbled kind of hard (maybe air lock, not sure) and the Control panel flashed red light. I powered off and ran water down through to push any air out then turned it back on and now the circ pump doesn't fire at all, and the control panel unplugged light is on on the board. I attached a pic of the board, the LIM OK light is green, then there is a green light on the heater relay part of the board as well. I just bought the board and circ pump 4 months ago so I hope its not bad again. Voltage wise I get 220 and 120 on the board as I should, but am showing 0 on the circ pump. Any ideas are appreciated, thanks in advance.
So the free hot tub cost me a little under $1000 but its working like new now, so it was still a good deal, just a lot of work... thanks everyone, especially RDspaguy for the help on getting this going. I appreciate it.
- 40 replies
- 1
- error
- flashing red light
I fixed it, I plugged the control in backwards😂 thanks
- 40 replies
- error
Thanks, wasn't sure if it was normal for no light, not even a blinking error light to be on the control head. I figured it must be bad since everything else seemed to be working (well at least the pump and aux panel). Will the jets not turn on from the aux panel if the control head is not functioning? Also the light didn't turn on from the aux button either, figured that was due to the control head too? But the aux was lit up at least.
- 40 replies
- error
Sorry, been a while thanks for all the help so far, I bought a new IQ2020 control box, new circ pump, and new aux panel. I replaced them all this weekend. Now when I power it up the circ pump does run, the aux panel does light up, but the control head does not light at all, no blinking light or anything on it. What would you suggest to do to troubleshoot? I was going to just go ahead and order the control head as well, but would like to be able to troubleshoot it first? The jets don't come on when I press it on the aux panel, but I am assuming that is because the control panel isn't working... Any help appreciated, again thanks for all the help you provided so far.
- 40 replies
- error
Thanks for confirming for me, that was my biggest worry (that I did something wrong) would you recommend replacing anything other than the board? Just wondering if a faulty part could've caused the motherboard fry? Don't want it to happen to a new board immediately. Or is there a way to test the heater and circ pump without a working board?
- 40 replies
- error
- 40 replies
- error
Attached are pictures of some voltage tests. 1st pic - Have 120 coming in to board from 20 amp gfci breaker 2nd pic - have 220 coming in from 30 amp gfci 3rd pic - have 120 going into other board 4th pic - 0 at circ pump 5th pic - 0 at jets The panel doesn't light at all either it was blinking red not anymore.
- 40 replies
- error
- 40 replies
- error
Ok. Let me know if you think of anything I could try. Hoping to avoid calling a tech in. The only one I could find charges $155 to show up and that covers 15 minutes then $100 an hour kicks in. So pretty much looking at a minimum of $255 + parts.
- 40 replies
- error
Yes, it is in the breaker as well, the schematics had no neutral for the 220 breaker.
- 40 replies
- error
