zich6
  • Content Count
    8
4 Neutral
About zich6
  1. Turns out I inadvertently put the controller in setup mode and assigned the pump 3 button to flip screen. All fixed and done. Thanks.
  2. I took great care of the tub this winter in North Idaho, but I just noticed pump 3 is not turning on. Are there any trouble shooting steps I can take (manual says bupkis) before I call a technician? The first error code 1.08 appeared, then upon subsequent presses the 1.6L appears. The manual has no error code listings, but it should. Thanks.
  3. I took great care of the tub this winter in North Idaho, but I just noticed pump 3 is not turning on. Are there any trouble shooting steps I can take (manual says bupkis) before I call a technician?
  4. Due to the malfeasance of someone in my household whom shall remain nameless, my 440gal. spa reached an alkalinity level of 280ppm. I treated yesterday with SpaGuard pH Decreaser sodium bisulfate (SB) and it's now down to 240ppm. I know I need to get to 80-120 ppm, so, my questions are: 1. How much of the SB can I add dissolved in a pail of water at a time and how long after the application do I need to wait before testing? Any other advice would be appreciated. TIA.
  5. Ok, thanks but I was thinking of setting the temp manually, it's much easier. I just lowered it 80 degrees, the lowest setting. Thanks.
  6. I have a two year old Costco Divine Sinclaire 3 pump spa. I won't be using it for several months and want to know the best storage temp to maximize energy efficiency, yet prevent freezing. What's the best temperature to set? Thanks.
  7. It is a Balboa pack. After letting it sit all night I cycled all the breakers again including the subpanel GFCI test and it booted up. We get some goofy power spikes here and that could possibly have been the culprit. Thanks for the excellent analysis and quick response. Nearest tech is a $300 trip charge away, so I'll be relying on this forum if I have problems in the future. Last week I replaced a leaking slice valve coupler myself. Thanks again.
  8. Last night the 2.5 year old tub (so out of warranty) shut off and the panel went dark. I cycled the main breaker and the subpanel 50amp breaker with no impact. The manual also says to check the fuse which I believe is a 7amp for the pumps. Before I take the panel off and start checking things, any advice? Thanks.
