Dansad,
The fix is the loose white pod. There should be no play on either pod. Replace ithe bad pod and or the inside blue plastic sticking out that has two black rubber bearings. Any play in the pod assembly connection will cause twisting hoses. Also make shure the shoes look OK and check the gearbox gears do not have any debree leeves, etc. inside. This will definetly fix your issue
Chris
