Thanks for the response. I'm betting you're correct. I wish I knew which piece was the relay, maybe could replace it without removing the entire panel. Tub is built into an indoor room, a bit tougher to work on since all is below floor/deck level. Thinking about simply hooking up waterproof external switch up to the jet pump and done with it. I have a good safe spot on the wall to put a switch.
